ICEM CFD- Error: prism terminated prematurely |
September 19, 2011, 13:47 |
I am trying to mesh a 3D geometry in ICEM and create prism layers. I am using tetra unstructured mesh.
I first generate the mesh, and run mesh check. There are no errors. Next I run prism and get the following error: ------------------------------ prism: swap. C:616: base_vertex* check_collapse(base_vertex*,base_vertex*,unstruc_m esh*,check_collapse_opts*,merge_data*): Assertion e1->ptwin()->ptwin() = e1' failed. Application is finished Error: prism terminated prematurely. ----------------------------------------- Does anybody have an idea what this error could mean? Thanks! |
September 20, 2011, 05:43 |
AB
Rep Power: 21 |
We need more info such as pictures of the geometry or how you proceed to specify your prism parameters !
September 20, 2011, 09:49 |
more information and reply
I am simulating is a 3D pi slice of a disk. There is a pi-shaped column of fluid above the pi slice. The disk is filled with a porous material and there is a suction cavity below the porous material.
I specify the prism parameters as: initial height: 0.001 height ratio: 1.1 number of prism layers: 20 There are prism layers along all of the walls, as well as on the surface of the disk. |
September 20, 2011, 09:53 |
Picture of geometry
Attached is a picture of geometry.
September 20, 2011, 10:03 |
More prism info
min prism quality: 0.00001
ortho weight: 0.5 fillet ratio: 0.35 max prism angle: 176 |
September 20, 2011, 10:05 |
AB
Rep Power: 21 |
Did you try to create only 1 prism layer to see what's going on ?
And post the picture of the result, it may help |
September 20, 2011, 10:16 |
pic of result
Here is a zoomed in picture of the result. It looks like it created 1 layer correctly. But creating multiple layers is causing a problem.
If you need a different view, just let me know! |
September 20, 2011, 10:23 |
splitting prism layer
I tried splitting the prism layer. Seems to work, but how come I can't create multiple layers at one time? I would like to be able to do that.
Is there advantage/disadvantage to either method? |
September 20, 2011, 10:55 |
AB
Rep Power: 21 |
I don't know why you can't create multiple layers at one time. Maybe ICEM acn't handle so many layers with your geometry. Maybe at some point, there are intersections which can't be fixed.
Make a research on this forum about that topic, you will find a lot of answers to your questions |
September 20, 2011, 13:21 |
It just won't fit...
Simon Pereira
Rep Power: 47 |
In the image you showed, there is a thinner lower region that is a green/teal color... This region is only 3 elements deep. If you try to grow too many layers, the corner of the prisms will come up at a 45 degree angle and will eventually get to close to the interface between the green/teal and the blue/cyan regions... Since that is a change in material, it represents a hard wall and prism will get stuck or break down...
You are not stuck with 1 layer though... Try 3 or 5 and see how it goes. Check and corner and see how tight things are getting to decide if you can try with a greater number of layers... Some times the number of layers you think you want just won't fit... You could even try different numbers of layers in different regions based on what the geometry can accommodate...
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
[ICEM] Icem CFD on Linux | mechanicaldesign | ANSYS Meshing & Geometry | 7 | March 11, 2021 19:44 |
Need help icem cfd | kakhtar | ANSYS Meshing & Geometry | 25 | January 31, 2017 01:09 |
Transport mesh from ICEM CFD, to Fluent, to Sysnoise | Wieland | FLUENT | 2 | April 15, 2012 06:28 |
Importing Solidworks part into ICEM CFD | MetalSupremacist | FLUENT | 0 | October 8, 2010 17:46 |
Importing geometry from Pro E to ICEM CFD V5.1 | sac | CFX | 2 | January 16, 2006 08:38 |
