[ICEM] Copy Blocking and Geomtry with Associations
Old   September 29, 2011, 12:37
Question Copy Blocking and Geomtry with Associations
Michael
Mick is on a distinguished road
Hi All,
Is there a way to copy the geometry and blocking where the block's associations stick with the copied geometry?
I copied the blocking with the geometry but the blocking was associated to the original geometry as opposed to the copied geometry.
Any help is much appreciated.
Kind Regards,
Michael
Mick is offline   Reply With Quote
Old   September 30, 2011, 03:33
AB
BrolY will become famous soon enough
From my experience, this doesn't work very well.
BUt you can try the following option : Blocking -> Blockin Associations -> Update Associations
BrolY is offline   Reply With Quote
Old   September 30, 2011, 09:53
Default Problem solved!
Michael
Hi BrolY,
That worked! Thanks for your help and the quick reply.
When I copied the geometry and blocks updating the associations worked except for one face-surface association but that was easy to fix.
Michael
