meshing on cylinder fails ICEM
Old   October 25, 2011, 05:21
Default meshing on cylinder fails ICEM
Jan Potac
potac is on a distinguished road
I have been meshing a cylinder domain with a model of a ship on the cylinder base. The ship itself contains some cylinder on the deck as well. The geometry is imported from workbench. When I have built diagnostic topology, everything seems to be all right (red edges). When I have tried to generate surface mesh using All Tri, Patch Dependent, I do obtain cells on all surfaces excluding the cylinders. I have tried different tolerances when building the diagnostic topology, and also setting of Shell meshing parameters (Ignore size) but without any improvement. Actually, it somehow helped before but cannot manage anymore. I am bit lost about the cause of that.
Does someone know what to check and do to get the surface mesh on all parts?
Thanks for any hints.
potac is offline   Reply With Quote
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 10:09
Structured meshing of a cylinder in ICEM vmlxb6 ANSYS Meshing & Geometry 4 October 19, 2010 16:45
Structured meshing of a cylinder in ICEM vmlxb6 ANSYS Meshing & Geometry 0 October 9, 2010 21:56
[ICEM] (ICEM CFD) meshing over a cylinder vmlxb6 ANSYS Meshing & Geometry 6 August 11, 2010 14:37
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
