[ANSYS Meshing] Free surface in Workbench
Old   November 2, 2011, 10:10
Default Free surface in Workbench
Vincent Meertens
vmeertens is on a distinguished road
Send a message via MSN to vmeertens
Dear all,
I have started to work witch Ansys Workbench since last week. Before that I was used to Gambit, but as Gambit doesn’t support 64bit, I was forced to switch.
I have to simulate the (free surface) flow around a hull, but I couldn’t manage to find a good tutorial how to set up such a model in Workbench.
Two main problems are:
-What is the best way to create a Flow Volume? (to set up boundary conditions like Inlet/Outlet/(moving) walls)
-In Gambit I used to “subtract” the hull from the flow Volume. How is that done in workbench? Is it simply done by defining the flow volume as fluid and the hull as solid?
Most of all, a good tutorial would help me the best, but answering the questions could be a good start :-)
Sincerely,
Vincent M.
vmeertens is offline   Reply With Quote
Old   November 3, 2011, 00:08
Sushilkumar is on a distinguished road
You can use Design modeler to generate the geometry, and in Ansys Mesher you can generate the mesh.
Sushilkumar is offline   Reply With Quote
Old   November 3, 2011, 02:35
Vincent Meertens
Thx for your reply!
I already have a geometry, but I can't find the similar operation as "subtract" in Gambit.
Now I have the hull in a box, but I'm not sure what the next step should be.
Old   November 3, 2011, 03:58
You can find this operation in,
Create=>Boolean=>Subtract
Old   November 3, 2011, 04:09
Vincent Meertens
Thanks a lot for your reply!
I will try it as soon as possible
Old   November 29, 2011, 09:15
Vincent Meertens
I’ve read some of the tutorials on creating volumes in Design Modeler.
I have to do some research on the fluid around a hull. For this I want the mesh to be finer on the free surface.
When I import the hull, I can use Enclosure for creating a box around the hull.
But how can I make a second volume at the level of the free surface?
Can I use Enclosure again to make a smaller box?
Or should I sketch the contours of the different boxes and use the Boolean operations?
Any help is appreciated!
Sincerely,
Vincent M.
Free surface is below than expected..results are not good mechovator CFX 24 April 8, 2011 00:41
Submarine Free Surface samwh CFX 7 August 30, 2009 07:14
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 18:13
Equilibrium of a free surface under surface tensio Ryan Main CFD Forum 1 August 7, 2001 16:14
Modeling Free Surface Flows Elliot Schwartz Main CFD Forum 5 August 25, 1998 21:03
