[ICEM] Problem with a narrow gap
Old   November 8, 2011, 09:58
Default Problem with a narrow gap
saisanthoshm88 is on a distinguished road
I was simulating the flow over some solar panel surfaces to compute the wind pressure on the panel surfaces. There is a narrow gap in between the panels and it is desired to have a good volumetric mesh refinement in this gap. I’ve used the curvature/proximity based refinement but that didn’t really help.
Could someone please suggest me the apt way to do this in ICEM.
Please find attached to this post a pdf that can provide a better illustration to the problem.
Best regards,
Santhosh.
saisanthoshm88 is offline   Reply With Quote
Old   November 8, 2011, 15:02
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Sorry, this was not really clear enough... I understand the model, but not what you mean by "it didn't help". Maybe you could post some images of the mesh that you don't like?
Was your min size small enough to fit several elements between each panel?
Another option would be to set a smaller size on the curves that form the perimeters of each panel.
If you are concerned about mesh count, this sort of model would be ideal for a 12 tet to 1 hex conversion process. This only works for octree tetra and can work even better if you disable the smoothing during octree mesh generation, then do the conversion (under change mesh type) and then smooth... Converting most of your mesh to hexas at a rate of 12 to 1 will save a lot of mesh...
If the model really is this simple, it may be a good candidate for ICEM CFD structured hexa or perhaps for cutcel (in ANSYS Meshing)...
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
