[ICEM] Function in Gambit, but hidden in ICEM CFD
Old   January 26, 2012, 07:42
Default Function in Gambit, but hidden in ICEM CFD
Matteo
matteogir is on a distinguished road
Hi everybody!!
as told in previous post i am an absolut beginner in cfd simulation. Some time ago I used to create geometry and to mesh with gambit and i remember that in a top-down approah, one was able to draw directly a cylinder or a cube and then merge them or intersect them ,instead of using the classical approach starting from points, then curves, surfaces and finally volumes.
I am looking for this feature also in icem cfd or in some related software included in ansys, is there this possibility?? may someone give me some hints to fix it up?
Thank you in advance!
matteogir is offline   Reply With Quote
Old   January 26, 2012, 09:17
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
search the forum with "top down approach" and this has already been explained in great detail by PYSMN. You can find this in create block tab
Far is offline   Reply With Quote
Old   January 26, 2012, 10:02
Matteo
mmm I have already looking for it, but i have found only one post about top down approach in which honestly i wasn't able to figure it out!
May be i haven't explained enough what i meant: i was dealing with "ready geomtrical components", i mean, in gambit u have the opportunity to build sphere, cones, cube only declaring some geometrical features like radius os else.
how can i do this in icem?
Old   January 26, 2012, 11:15
Far
Sijal
geometry > create/ modify surfaces > standard shapes (last option)
gambit 64 bit?? artemiss1984 ANSYS Meshing & Geometry 23 November 21, 2016 01:07
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
Gambit, Gridgen or ICEM CFD sam Main CFD Forum 5 October 7, 2006 02:20
