[ICEM] Mesh a pie geometry with hexahedral and prism elements
Prev Previous Post   Next Post Next
Old   January 24, 2012, 13:06
Default Mesh a pie geometry with hexahedral and prism elements
mgu
Mingyao Gu
mgu is on a distinguished road
I would like to produce a structured mesh for a pie section that in the radial direction has one layer of prism elements at the center of curvature and multiple layers of hexahedral elements away from it extending to the circumferential arc. The result should be a grid with the same number of angular elements at each radial position. My question is what is the best way to create a mesh as described in ICEM CFD. Thank you.
Mingyao
mgu is offline   Reply With Quote
mesh, pie, prism
Tetrahedral vs. Hexahedral Meshing for CFD Andy Bartels Main CFD Forum 16 September 20, 2019 10:06
[ICEM] Meshing on a Complicated Geometry tav98f ANSYS Meshing & Geometry 2 August 17, 2011 11:15
Can Fluent handle a degenerate block? Error while reading mesh... Anorky FLUENT 1 May 1, 2010 12:47
[Gmsh] Modified gmshToFoam to help import hexahedral and prism elements from Gmsh adorean OpenFOAM Meshing & Mesh Conversion 1 April 18, 2005 08:19
