[ICEM] Negative Volumes in Ahmed Body Meshing
Old   October 12, 2014, 12:39
Default Negative Volumes in Ahmed Body Meshing
Akshay Deshpande
akshaydeshpande is on a distinguished road
Hi all,
I am a beginner in ICEM CFD. I have meshed the Ahmed body in ICEM by following the tutorial on youtube and exported the mesh to Fluent. Even though there are no negative volumes in ICEM CFD (Fig 1), Fluent shows the error of presence of negative volumes. I have tried re-blocking and smoothing but the error persists. I have also attached a detailed picture of my mesh.
Please help!
akshaydeshpande is offline   Reply With Quote
Old   October 12, 2014, 19:51
hwet is on a distinguished road
i would suggest just use ansys meshing in workbench for this model rather than icem cfd
hwet is offline   Reply With Quote
Old   October 13, 2014, 09:19
Akshay Deshpande
Thanks for your reply! As far as i know, Ansys meshing gives an unstructured mesh. so will it be better than the structured mesh for calculations?
Old   October 13, 2014, 22:20
u can slice ur body into parts, simple geometry parts will have hex mesh then and complex may have tets (hybrid meshing), recently at a cfd conference an expert working with ansys explained that gone are the days when the solver did not give good results with tets, just remember to have inflation layer near the wall (10-15), having tets elsewhere is good enough.
Old   October 15, 2014, 12:41
Akshay Deshpande
Thanks! I will try that. Meanwhile I am trying a 2d analysis of the same case but am getting problems while importing it to fluent. To rectify this:
1. I have checked for all associations along the perimeter curve by turning on the line elements and turning off the shells
2. I did an uncovered face check but no problem was found.
Even after following these steps, I am facing the same problem. I have attached images for reference. What else needs to be done?
Old   October 16, 2014, 12:16
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
check this http://www.cfd-online.com/Forums/ans...h-quality.html
Far is offline   Reply With Quote
Ahmed Body andrea.pasquali OpenFOAM 10 June 18, 2016 03:16
Ahmed body drag coefficient IvanST FLUENT 0 December 18, 2012 09:17
Can't get good results on ahmed body research Michael Main CFD Forum 8 September 17, 2008 13:55
How to exclude volumes from meshing in ICEM Evgeniy CFX 2 November 4, 2005 12:09
negative grid volumes when adapting Dave FLUENT 1 August 20, 2005 13:47
