[ICEM] Deleting unwanted edges
Old   February 1, 2012, 12:31
Exclamation Deleting unwanted edges
dale
protea is on a distinguished road
Hello everyone can anyone tell me how to delete the unwanted edges which are not necessary in geometry. For my geometry when i build topology, near the flaps its showing multiple edges(Blue curves), so untill i remove them i cannot go further go in meshing. So could any of u guys who already worked in this kind of situation please help me out in proceeding further and hoping for ur positive responses.
Regards
Dale
protea is offline   Reply With Quote
Old   February 2, 2012, 01:24
arjun
arjun3020 is on a distinguished road
you can proceed with blue edges, there is no need to delete blue edges.
problem arises only if u have yellow edges.
arjun3020 is offline   Reply With Quote
Old   February 2, 2012, 01:31
dale
thanks arjun for ur reply, yes indeed i proceeded further by ignoring them but i was not able to get the desired mesh in those particular regions. So the only other solution is to remove them first and go ahead. If u know the procedure how to do it, cud u plz share ur thoughts on this, it will be very much helpful to me. Thanks in advance.
Regards
Dale
Old   February 2, 2012, 01:45
arjun
i dint understand your main problem. i think that edges dint affect the mesh.
what type of mesh u did?
tell me more about geometry or send me your project at - arjun3020@gmail.com
i will check it.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Deleting Edges in Gambit Alberto Schroth FLUENT 4 May 31, 2000 14:15
