[ICEM] Faces Not Matched in ICEMCFD
Old   February 5, 2012, 14:16
Default Faces Not Matched in ICEMCFD
Konstantinos
kostas is on a distinguished road
Hi to everyone,
i am a new user of ANSYS ICEMCFD and right now i am dealing with a 3D geometry. Until the output process, i do not encounter any problem. However, when i am generating the .msh file,i see different number of faces between the opposite surfaces. After trying to reduce the nodes of my mesh, the faces were matched. However, i do not have the desired number of nodes. What can i do in order to have both the desired number of nodes and matched faces?
I used also association mesh to geometry. I also tried to extrude the mesh.again, the faces did not match.
THANKS
kostas is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
