[ICEM] hexa mesh nodes associated mistakenly, need help
Old   October 30, 2013, 05:46
Default hexa mesh nodes associated mistakenly, need help
SHAN
hsn3hao is on a distinguished road
When I built a hexa mesh for a metal block in flow, I meet a problem that all nodes in a line connect to a point which looks like the attached pic. Does anyone knows where is my problem? and how to fix it?
Many thanks
Shan
hsn3hao is offline   Reply With Quote
Old   October 30, 2013, 08:45
kad
kad will become famous soon enoughkad will become famous soon enough
First you should check associations of edges and verts. But I think you have already done that, right? Very rarely ICEM associates faces wrong without any obvious reasons. I had a similar problem when using copy periodic blocking. It helped to associate the affected faces manually. I think I used the option associate to part.
kad is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
