[DesignModeler] Creating Fluid Body Inside Solid Part
Old   February 7, 2012, 15:55
Default Creating Fluid Body Inside Solid Part
James
VU_Engineer is on a distinguished road
I the stp files from a ProE drawing of an exhaust stack. I am using ANSYS Workbench 13 with CFD FLUENT. I want to take the solid stack walls that I've imported, and create a fluid body inside. Does anyone have experience with importing solid bodies for a CFD simulation?
VU_Engineer is offline   Reply With Quote
Old   February 24, 2012, 21:28
Erik
evcelica is on a distinguished road
Use the fill option in design modeler, I think its under tools > fill. then pick the inner surfaces and it will fill, you may have to specify "add frozen" instead of "add material"
evcelica is offline   Reply With Quote
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
conjugateHeatFoam: Should solid and fluid have the same mesh at the coupled boundary? awacs OpenFOAM Running, Solving & CFD 6 September 22, 2009 22:58
Extracting fluid flow region from a solid body 3D Pradeep Main CFD Forum 6 January 29, 2009 11:13
fluid structure interaction taru agrawal FLUENT 4 September 10, 2007 03:12
cooling a solid body Ralf Schmidt FLUENT 1 April 16, 2007 10:54
