[ICEM] Blocking topo for hexagonal tube with holes |
February 9, 2012, 10:44 |
Stuart
Rep Power: 25 |
Any ideas for blocking this hexagonal tube with an orifice in it? I'm using a hexagonal section as it makes a nice geometrical symmetry for the 6 surrounding holes and corresponding fluid symmetry boundary conditions along the tube length. The green surface around the hole is to be no-slip walls. and it's also showing the outflow surface. This might be straight-foward for some but my DNA lacks PSYMN's blocking gene so I can never "see" blocking topos. Thanks |
February 10, 2012, 07:47 |
AB
Rep Power: 21 |
I would first create a block for the whole tube.
Then cut it in the middle to capture the hexagonal section. Then create O-grid. Then cut again to capture the small orifices. Could you post your geometry here so I could have a quick look ? |
February 10, 2012, 08:41 |
I would second the comments of BrolY and would like to add this: create six Y-blocks for six opening (orifices) at the periphery of hexagonal section and full o-grid in center for circular section.
February 10, 2012, 14:17 |
Stuart
Rep Power: 25 |
Thanks for the replies.
Geometry (*.tin) file uploaded. Last edited by siw; February 13, 2012 at 03:29. |
HLL Riemann Shock Tube Matlab Problem | Luke F | Main CFD Forum | 2 | May 20, 2016 02:10 |
What is best mesh for cylinder tube? | olivia | FLUENT | 7 | January 16, 2014 05:55 |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
Tube inside a tube simulation | Rashmichem | Main CFD Forum | 0 | December 14, 2010 01:52 |
Flow through multiple holes | Matthew Markham | Main CFD Forum | 3 | January 28, 2009 21:47 |
