[ANSYS Meshing] Mixing structured with unstructed mesh
Old   February 22, 2012, 05:17
Default Mixing structured with unstructed mesh
hadrien calmet
hadrien51 is on a distinguished road
Hello everybody
I trying to mesh a surface boat with the bottom structured and the rest unstructured.
Check this post:
http://www.cfd-online.com/Forums/ans...tml#post345599
I want to do the same mesh than the picture but with the boat, mixing structured with unstructured. I use in volume mesh the octree method and existing mesh part (for including the structured mesh)
I put the tin and the blk in dropbox.
http://dl.dropbox.com/u/3423073/casco.blk
http://dl.dropbox.com/u/3423073/casco.tin
I am not capable to mesh it ! I do it for the appendices (picture) but for the boat , this is not working, perhaps about the topology or faceted surfaces of the boat.
If you have a solution or advice.
Thank you in advance
hadrien51 is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
Structured Grid Definition craig shores Main CFD Forum 3 March 21, 2001 14:48
