[DesignModeler] How to array a geometry in sketch?
Old   March 12, 2012, 06:07
Default How to array a geometry in sketch?
Rikio
rikio is on a distinguished road
Send a message via Skype™ to rikio
There are many rectangles distributed on a plane, and I want to split the surface into small pieces with these recs. But I can not find any array tool in sketch environment. It would be really a tedious job to repeat the drawing and dimensioning. Could you know any hints to finish such kind of work?
Thanks for any suggestions.
rikio is offline   Reply With Quote
Old   March 13, 2012, 23:06
Rikio
Have not found any function could get this very quickly, but grid would help a little. However, only one dimension of the grid could be defined, i.e. it is inconvenient to draw a rect whose length is different from the width. Major grid and minor grid may work, but can not set the length to random values.
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
Help Needed in Geometry for jet Array impingement in Cocentric Tube Annulus Excel Main CFD Forum 1 April 18, 2010 10:31
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
Geometry array in Gambit CUser FLUENT 0 November 1, 2008 10:50
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
