[DesignModeler] How to import multiple stp file to design modeler
Old   March 25, 2012, 00:37
Default How to import multiple stp file to design modeler
eslam
eslamkashi is on a distinguished road
Hi
I have about 1000 stp file which must be imported to desighnmodeler, really I have 100*100*30 meter environment that those 1000 part must be cutting from it and we have air flow betwen them.
My first problem is importing these parts and second problem is meshing it (because some of parts are very small), please write your sugestions.
eslamkashi is offline   Reply With Quote
Old   March 25, 2012, 01:33
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
just import the stp file!!!
Far is offline   Reply With Quote
Old   March 25, 2012, 01:45
eslam
At least 4 click need for 1 import!!!!! I have 1000 part, and about mesh?
Old   March 25, 2012, 01:55
Far
Sijal
http://www.padtinc.com/blog/post/201...ing-Forms.aspx
Workbench has IronPython built into it from the ground up
You can record whatever you do in the GUI to create scripts
You can read those scripts in to control Workbench
ANSYS uses IronPython because it talks to Windows programs
Get detailed info at www.python.org, www.ironpython.net, and www.ironpython.info
Most of the examples below are derived from information I got at: http://www.ironpython.info/index.php...#Windows_Forms
Page 240 of this user guide may help you
http://www1.ansys.com/customer/conte...121/wb2_js.pdf
Old   March 25, 2012, 03:09
eslam
Thanks, I'll read it. However my stp files are in different folders and I think I will not work with script
Now if we assume that I can import them, do you have any idea about meshing it in workbench?
Thanks again
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 14:22
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[DesignModeler] How to import AutoCAD file into Design Modeler? CFD-Jay ANSYS Meshing & Geometry 23 July 28, 2017 06:24
How to import a AutoCAD file into Design Modeler? CFD-Jay FLUENT 1 July 8, 2010 10:49
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
