April 17, 2012, 14:21 |
Multiple Blocks in one Project
OK so I'm on the road to mastering this software and I've just started my trip. I'm working with a geometry for practice that has three separate parts in it. I want to block mesh those parts but they are not connected at all so I need three different blocks. How can I create three separate blocks that do not depend on each other? When I do make more than two blocks the software asks me if I would like to merge or replace the current block. If I replace then the work I've done is gone but if I merge then it changes the parameters in the first block. How do I use multiple blocks?
blocking strategy |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 05:59 |
dsmcInitialise - dsmcFoam | archymedes | OpenFOAM Pre-Processing | 94 | July 15, 2016 16:14 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
[snappyHexMesh] Meshing multiple blocks | Hanno | OpenFOAM Meshing & Mesh Conversion | 3 | February 17, 2011 12:14 |
