[ANSYS Meshing] Ansys Meshing particle packing
Old   March 30, 2012, 12:38
Default Ansys Meshing particle packing
Nathan
natantyt is on a distinguished road
Hi
I have a packing of particles with overlaps enclosed by a box which forms the fluid region, I have used ansys automathic meshing with refinement leads to poor mesh with skewness over 0.9 and I can't get convergence in Fluent doing flow analysis . I have tried multizone failed due to input parameters. Do you have any idea of steps to get quality mesh on this complex geometry?
Sample picture below
natantyt is offline   Reply With Quote
Old   March 30, 2012, 22:52
Sarang Dalne
sarangdalne is on a distinguished road
Try using patch conforming or patch independent methods in combination with the "On: Curvature and Proximity" advanced size function.
I am not sure which version of ANSYS you are using, if you have the latest then try using cutcell or tetra methods also. But, in that case you have to be cautious about the element size you give as your mesh resolution will be very much dependent on it. Also, if you just want to mesh the fluid region try the concept of virtual bodies and mesh groups.
Let me know if you specific questions.
Thanks,
Sarang
sarangdalne is offline   Reply With Quote
Old   April 12, 2012, 15:54
Nathan
Thanks for the reply,
I've used the patch conforming with proximity and curvature, I still get skewness of above 0.9 for around 100 cells out of 5 million. It is not possible for Fluent to convert them skewed mesh to polyhedral, so I need to localy manipulate them , do you have any suggestions. Refining makes the number of cells very high which will increase the computational cost very much.
[ANSYS Meshing] Ansys Meshing Error on Generation resnik ANSYS Meshing & Geometry 3 February 14, 2024 23:43
Check particle impaction with User Fortran Julian K. CFX 3 January 12, 2012 09:46
Ansys Design modeler particle packing natantyt ANSYS 0 October 14, 2011 18:09
Particle User Source in ANSYS CFX Jun CFX 0 September 8, 2010 09:28
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
