June 20, 2012, 07:42 |
Problem with GAMBIT
Francesco
Rep Power: 13 |
Hi, I'm trying to convert a mesh in GAMBIT v2.2.30. The extension of my starting file is .cas and I want a .msh. To do this, first I've to open my .cas file. If I click <<file>>, <<import>>, <<mesh>>, under the <<type>> menu I select Fluent 5/6, dimension is 2D, then I select my file but GAMBIT give me this error:
ERROR: Error encountered while reading the header information. GAMBIT is unable to import |utility fe2ram -m1e-006 -d2 -tRAMPANT -oFIDAP7 C:\Documents and Settings\Utente\GAMBIT.568\caso1.cas further information may be available in the Gambit start window/terminal What about the error? What I have to do? Please help me! Thanks a lot Last edited by Bombolati; June 20, 2012 at 08:03. |
[GAMBIT] problem with importing geometry in Gambit | bahar | ANSYS Meshing & Geometry | 27 | December 12, 2014 00:57 |
Gambit geometry problem | cestrin | FLUENT | 3 | July 4, 2012 02:33 |
Gambit starting problem | Kwiaci | ANSYS | 0 | December 4, 2011 05:43 |
[Commercial meshers] Problem with Mesh conversion Gambit msh Foam | Rachid BANNARI (Bannari) | OpenFOAM Meshing & Mesh Conversion | 25 | September 11, 2011 07:58 |
Startup Problem in Gambit 2.2 with WindowXP | Win Win Maw | FLUENT | 3 | January 25, 2006 11:09 |
