November 22, 2012, 11:12 |
DPM injection mass flow rate
Mina
Rep Power: 13 |
Dear all
I have a question , kindly bear with me the following If my injection flow rate is 1.5 g/s and particle time size is 0.001 (unsteady tracking ) No. of time size =1 i.e. the pulse of the injection will be short (1*0.001 ) the start and stop time of the injection was set to 0 -300 sec. and the no. of particles is 60 droplets 1) Fluent at each DPM injection is injecting the 1.5E-3 which is 1.5 *0.001 and this no. is not increasing , why ??? 2) the Update DPM option is really affecting the convergence time , but what i don't understand is the relation btw that option and the famous graph of URF interphase exchange terms 3) in the best practice guide : they are saying to reduce the URF of DPM and increase the no of continous iterations per DPM iterations , which is totally contradictory with the 2 way couple strategy and to the above mentioned graph . i.e for the results to take effects the URF of DPM should be increased and the no. of iterations of the continous phase /DPM iteration to be reduced Please advice |
Mass flow rate of the DPM mass sourse ?? | Rhinocao | FLUENT | 3 | January 21, 2011 12:10 |
mass flow rate on the Iso-clip surface & interior | Sunil Gupta | FLUENT | 0 | April 22, 2008 09:29 |
DPM outlet mass flow rate | vk | FLUENT | 1 | April 18, 2008 14:13 |
mass flow rate error | Masood | FLUENT | 0 | May 22, 2005 00:32 |
mass flow inlet | Denis Tschumperle | FLUENT | 7 | August 9, 2000 02:19 |
