Import Heat flux into Ansys Workbench
Old   April 19, 2013, 05:10
Default Import Heat flux into Ansys Workbench
Riffraff is on a distinguished road
Hello everyone,
I am trying to simulate the thermal behavior of an experimental setup using the steady state thermal solver in workbench 14. As a thermal source I can define a heat flow through a surface - the problem is that in my case I do not want a uniform distribution, but to import an nonlinear distribution from a different source.
Is this possible to achieve? I'm very new to using ANSYS, thank you for any help.
Best regards,
Raphael
Riffraff is offline   Reply With Quote
Old   April 20, 2013, 10:13
dklastiwka's Avatar
Derek Lastiwka
dklastiwka is on a distinguished road
If you are solving a thermal problem in a solid body you can do this in ansys cfx directly. Look up conjugate heat transfer in CFX. You can specify a cfx domain to be a solid and associate thermal properties with it. Then solve both the solid and fluid domains at the same time.
Derek Lastiwka
Mechanical & Fluids Engineer
dlastiwka@graymattereng.com
Gray Matter Engineering Inc.
dklastiwka is offline   Reply With Quote
Old   May 8, 2013, 07:55
Thank you for your response dklastiwka and please excuse the long delay in answer.
I've taken a look at cfx, but I I didn't get anywhere, as it seemed to be designed for problems involving fluids.
Maybe I should make my initial problem clearer. I am trying to solve a thermal problem, where heat flows into an object through a flat, circular face. The heat flux distribution I want to consider is however rather complicated. I have the values of the heat flux at discrete points on a grid for (x,y) coordiante pairs. What I need now is a way to take this discrete distribution, interpolate it if necessary and then use it as a heat source in my model.
Thank you and best regards,
Raphael
Total heat transf. rate vs Total surface heat flux Renato Sousa FLUENT 1 April 14, 2020 03:27
Heat Flux , Convective + Radiant Heat flux Mandeep CFX 3 October 25, 2012 16:57
Can't import geometry file from Icem CFD to Ansys Workbench Julien87 ANSYS Meshing & Geometry 1 July 19, 2011 16:50
heat flux distribution gtheo CFX 2 April 27, 2011 03:36
Heterogeneous heat flux Kev STAR-CD 4 July 7, 2009 04:48
