how to show array over the steamline in CFD-post |
May 31, 2013, 01:19 |
Astio Lamar
Hello everybody.
I want to know if it is possible to show the direction of streamlines by some sort of array? thanks. |
June 1, 2013, 20:41 |
Rep Power: 19 |
June 3, 2013, 05:02 |
Astio Lamar
Hello and thanks for your reply.
But the arrowheads are not Coincident exactly the streamlines. there is no any other solution? |
June 3, 2013, 09:38 |
Rep Power: 19 |
Did you set the Vector location to the streamline?
June 3, 2013, 16:34 |
Astio Lamar
Hello
How can I do this? I have Plotted both in over the same face |
June 3, 2013, 22:01 |
Rep Power: 19 |
Create a streamline from any location you desire (surface, plane, polyline, etc.).
Create a vector using the streamline as the Location and configure as you desire. That's it. Now, if you are going for a very specific type of look, then we need a bit more of a description or example. |
June 4, 2013, 05:09 |
Astio Lamar
Dear mjgraf
Thanks for your time and reply. I follow this: First I plot the 2D streamline over a surface "streamline 1". them I plot a vector by the following properties: Locations "streamline 1" But by choosing the streamline as location, no vector shown over the streamlines. Moreover I try to use the Symbol tab of streamline to show the Arrow head from there, but the problem there is that, there is no option to plot symbols tangentially since the streamline is plotted in 2D. thanks. |
June 4, 2013, 08:07 |
#8 | |
Rep Power: 19 |
From what you are now describing, it seems you are performing a surface restricted streamline on a WALL. This adds a little twist. The vector must be changed to use Conservative Boundary Data.
Also, a streamline by definition is tangent to the velocity vector of the flow. Quote:
June 5, 2013, 19:05 |
Astio Lamar
Hello!
So is there any solution in the case? why when I want to plot arrowheads over the stramline location, nothing shown? |
June 5, 2013, 19:41 |
Rep Power: 19 |
try checking the normalize button in the vector size.
the method I provided is the solution. either you are doing something wrong or there is an oddity with your setup. |
June 6, 2013, 05:00 |
#11 |
Astio Lamar
Hello.
I use the method that you mentholated, you can see the results in the attached figures. But I am looking for the plot exact same as you attachment. |
November 30, 2016, 13:41 |
#12 |
mao
Rep Power: 10 |
hi, i meet the same problem , have you fixed it ? thank u
March 2, 2021, 16:26 |
#13 | |
Wasi
post graduate opportunity in CFD application in Military | teguhtf | Main CFD Forum | 1 | February 27, 2024 06:29 |
calculating output parameter in cfd post | markus67 | CFX | 3 | August 26, 2015 09:28 |
Setting the desired Zoom level in ANSYS CFD Post for custom reports | shreyasr | CFX | 1 | July 11, 2013 01:57 |
Cfd post | Manish Kumar | ANSYS | 2 | February 22, 2013 00:29 |
Automated post processing using CFD Post | shreyasr | ANSYS | 0 | January 28, 2013 06:21 |
