Home > Forums > Software User Forums > ANSYS
ansys fluent solver "cannot change surface_body to fluid" warning
Like Tree1Likes
  • 1 Post By supersonicturtle
Old   October 13, 2013, 17:12
Default ansys fluent solver "cannot change surface_body to fluid" warning
ahmet
supersonicturtle is on a distinguished road
Hi, i wanted to simulate inviscid flow over cylinder. I draw two circles and subtracted the small one from big one and formed a mesh over it. In the setup section, i see : "cannot change surface_body to fluid, they are incompatible types" warning. I checked if the mesh area is frozen in dm and changed it from solid to fluid. After updating, i see the same error again. The error causes not to display anything except for "general" and "material" sections in the setup so cant see boundary cond or any other thing. What should i do?
Thanks in advance.
Luiz Pancini likes this.
supersonicturtle is offline   Reply With Quote
Old   January 17, 2020, 06:46
Aksit Serhat
aksitserhat is on a distinguished road
Hi, Now i have the same problem. Have you solved it?
aksitserhat is offline   Reply With Quote
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 10:54
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 02:00
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 10:20
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 04:35
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
