January 6, 2014, 01:58 |
Importing solid works 2D drawing to Ansys
Anvesh
Rep Power: 12 |
I am new to using Ansys. I have a problem in importing a 2D drawing to Ansys design modler (I created geometry in solid works) in work bench. It is showing
" No valid bodies found" when i was trying to import. Please help... Thank you. |
January 16, 2014, 11:29 |
convert to surface
Nabeel
the best way is to change your 2d graph into surface while you are in solidworks, and then you can import to ansys / fluent.
2d file, import, solid works |
[DesignModeler] How to avoid duplicate faces when Importing from GAMBIT to ANSYS 14 | yahya | ANSYS Meshing & Geometry | 0 | December 17, 2012 10:15 |
[ANSYS Meshing] Importing a model from GAMBIT to ANSYS 14 | yahya | ANSYS Meshing & Geometry | 0 | December 14, 2012 04:03 |
[DesignModeler] Importing Solid Edge ST4 Geometry into Ansys Fluent 13.0 for meshing | The Mighty Rearranger | ANSYS Meshing & Geometry | 0 | November 27, 2012 12:44 |
importing mesh from Gambit and other software to ansys workbench | mortazavi | ANSYS Meshing & Geometry | 5 | June 6, 2011 11:09 |
importing mesh to ansys workbench??? | mortazavi | ANSYS | 0 | June 1, 2009 05:10 |
