Problem with rotation (ANSYS by script)
Old   February 28, 2014, 17:57
Default Problem with rotation (ANSYS by script)
etastar68 is on a distinguished road
Dear All,
I use ANSYS in order to deliver electric field calculations to be used as input for Garfield++, a toolkit for gaseous radiation detectors simulation. I wrote a script which defines the geometry of the detector and solves the electric field. I get the nodal solution as .lis files. I just figured out that the orientation of the coordinate system in ANSYS does not match with the one in Garfiled++. I need to transform Z into Y axis and so on. I went through tutorials for rotation but did not find any command to add my script in order to rotate the nodes list. The other option is to rewrite the code but it is very complicated (thousands of lines of code).
Does anyone have an idea to help me?
Thanks a lot in advance.
etastar68 is offline   Reply With Quote
[ANSYS Meshing] 2-Way FSI meshing problem using ANSYS 13 workbench john881129 ANSYS Meshing & Geometry 0 January 9, 2012 01:19
Strange ANSYS Meshing 13.0 Problem brunob ANSYS Meshing & Geometry 3 June 21, 2011 20:03
Ansys Workbench (CFX) bucket problem njsavage CFX 1 April 30, 2009 09:51
Ansys CFX bucket problem njsavage Main CFD Forum 1 April 30, 2009 09:48
Problem Setup: Bi-Axial Rotation Possible? Harmeet CFX 6 February 11, 2005 15:27
