March 14, 2014, 08:37 |
Reset units in Ansys Geometry
Benjamin
Rep Power: 12 |
Hi, I have created an Ansys Geometry using Meters as the scale.
How do I change the units to mm. Also, will it affect other components that i link to like fluent and transient structure. Thanks |
March 16, 2014, 23:50 |
Alex
Rep Power: 12 |
go to the units tab and set "display in project units" on. then change the project units to whatever you like. should work. this will not affect any of the results as long as you are working in ansys with ansys meshing. when exporting to icem, it sometimes gets a little confused but then you can just scale down the geometry.
[TurboGrid] GE rotor B geometry for Ansys turbogrid | sonny | ANSYS Meshing & Geometry | 6 | August 29, 2014 20:01 |
Ansys Design Modeler complex geometry | natantyt | ANSYS Meshing & Geometry | 1 | October 17, 2011 08:57 |
Problem importing GAMBIT mesh to Ansys geometry | David G. | CFX | 0 | June 19, 2005 06:01 |
Stirred Tank Geometry in Ansys | gopalkasat | CFX | 6 | December 22, 2004 13:32 |
To dimensionalize or not to dimensionalize !! | tolani owosina | Main CFD Forum | 8 | November 13, 1999 13:45 |
