Test case not converging
Old   June 13, 2016, 10:54
Default Test case not converging
Yunus
Yunus is on a distinguished road
Basically what I'm trying to do is a biological model of a breast. I created a testcase, which is a simple hemisphere, set the plane representing the chest wall to zero displacements and applied a gravity parallel to the plane. I'm using a linear elastic model. Unfortunately it just converges only up to 1/10 of the earths gravitational pull, any gravity bigger triggers the output UNCONVERGED SOLUTION.
I'm using 10node tetrahedral elements. I've already tried different mesh sizes and time steps.
How can I get the testcase to converge?
Thank you in advance.
Yunus is offline   Reply With Quote
Need a 3D unstaedy test case for code validation usyusuf Main CFD Forum 0 February 14, 2014 13:53
Viscositymodel tutorial, problems when changing test case to cavity sur4j OpenFOAM Programming & Development 1 December 8, 2013 09:53
T3c2 flat plate test case rajeshamech Main CFD Forum 0 November 21, 2013 05:21
rhoSimpleFoam - test case atareen64 OpenFOAM Running, Solving & CFD 5 May 1, 2011 17:17
Porous Media test case Alex FLUENT 0 April 9, 2006 08:23
