Home > Forums > Software User Forums > ANSYS
Icepack no convection
Old   February 5, 2015, 11:23
Default Icepack no convection
Christoph
Christ0ph is on a distinguished road
How to disable the convection solving in Icepak?
I know it is not the purpose, but I would like to compare with and without air convection of a full assembly.
I've found only a way to force no heat exchange on a surface by setting the factor area to ~0.001 of each faces of a block for instance.
(If it set at 0, it looks to not be taken in account. Same if the fixed heat of a surface is set at 0 W of a surface, it calculates anyway a heat exchange.)
thanks for your help,
Chris
Christ0ph is offline   Reply With Quote
Old   May 8, 2015, 02:37
Default Hi
Pramodh.J
Jupudi.pramodh is on a distinguished road
Send a message via Skype™ to Jupudi.pramodh
Chris,
You can either switch off Convection by switching off the flow equation under Basic settings. similarly you can also do this by deactivating the cabinet object.
Let me know if any of these two options worked out..
Jupudi.pramodh is offline   Reply With Quote
Old   May 10, 2015, 17:38
Christoph
Dear Jupudi,
Thanks a lot for your feedback.
Indeed, I've found the option to disable the cabinet which works.
But I did not know about the flow equation which could be turn off.
Regards,
Chris
Old   May 11, 2015, 02:57
Default Hi
Pramodh.J
Hi Chris,
Glad to know that you've found Cabinet Off option (Cabinet Type: NONE).
Regarding the flow equation, you can check out the same window where you'll be switching on radiation, gravity and flow regime. Just un check the radio button adjacent to "Flow" .
Let me know if you face difficulty in finding it.
thanks,
Pramodh
Old   July 12, 2019, 05:00
Post Hi
Alessandro
Alex131191 is on a distinguished road
I'm analyzing electronic modules of a small satellite in Icepak, but I have few doubts on how I'm setting the simulations.
I tried switching off the cabinet to simulate the space environment, as suggested by Jupudi in this post, but I obtained very high temperatures (around 500°C, instead of an expected average of 100°C for the most powerful IC package).
Thus, I'm setting every side of the cabinet as Opening, enclosing the model of the satellite inside the cabinet with some space in between.
Moreover, I'm using a very rarefied air as default fluid, and I'm setting the Radiation Temperature to 20°C (while the Ambient Temperature varies along the simulated orbit), but I'm not sure that this is the right value I should use.
Sorry for the lengthy message, but it is important for me. A helpful reply would be much appreciated
Thanks and Regards,
Alessandro
Alex131191 is offline   Reply With Quote
convection, icepak
Simulation of Rayleigh-Benard convection n0name Main CFD Forum 2 April 27, 2014 13:49
Thermophysical properties for natural convection Ciefdi OpenFOAM Running, Solving & CFD 0 November 7, 2013 11:44
simulation problem -- convection BC pras FLUENT 4 January 30, 2013 10:41
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 s.mishra ANSYS 0 March 31, 2012 04:12
natural convection problem with radiation jorien CFX 0 October 14, 2011 09:26
