April 9, 2016, 06:06 |
Modelling Transient Heat Conduction
Sankeerth
Rep Power: 11 |
An exothermic process occurs uniformly throughout a 10-cm-diameter sphere (k 300 W/m · K, cp 400 J/kg · K, r 7500 kg/m3), and it generates heat at a constant rate of 1.2 MW/m3. The sphere initially is at a uniform temperature of 20
C, and the exothermic process is commenced at time t 0. To keep the sphere temperature under control, it is submerged in a liquid bath maintained at 20 C. The heat transfer coefficient at the sphere surface is 250W/m2 · K. a) Predict the steady-state temperature of the sphere. b) Calculate the time needed for the sphere temperature to reach the average of its initial and final (steady) temperatures. How do i model this problem in Ansys? Please reply at the earliest |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Heat transfer (conduction) between two pipes | shields | FLUENT | 14 | February 3, 2016 07:45 |
Geothermal Reservoir 2D heat flow modelling | phobo | ANSYS | 0 | May 25, 2014 10:10 |
Transient conduction possible in fluent? | jlefevre76 | FLUENT | 2 | February 5, 2013 09:53 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 12:02 |
