"problematic geometry"
Old   March 16, 2011, 13:47
Default "problematic geometry"
svp89 is on a distinguished road
Hi, I am wondering if anyone can help me as I am new to Ansys:
I have drawn a model of a propeller blade in solidworks and imported the geometry several times using Parasolid, ACIS and IGES files; I get the same problem with all files. I am trying to model the thrust and centrifugal forces acting on the blade, however there is a problem within the meshing stage...
- Upon trying to mesh the blade in Workbench I recieve a notice stating that there is problematic geometry as shown in the attatchment below:
Can someone help me resolve this issue?
Thank you very much!
svp89 is offline   Reply With Quote
Old   March 17, 2011, 05:09
Andreas
tallknuseren is on a distinguished road
This is what we call "dirty CAD"
You may have a small fault or discontinuity in your geometry, leading to this error message. Repair functions in Design Modeler may work, or else you must thoroughly go through the history tree of your geometry in your CAD-system, and look for small edges or faces missing in selections, etc..
tallknuseren is offline   Reply With Quote
Old   March 17, 2011, 10:39
Hi, thanks for your quick reply. I have just tried the repair functions in Design Modeler and it says there are no faults... I am going to review the CAD drawing but when I last checked nothing seemed to be wrong with it. The only thing I can think of is that the tip of the blade was formed via an extrusion from a sketch at the end of the mid section to a single point; as this was the only way i could get the desired shape... I guess I will have to play about with that and see what happens.
Old   March 18, 2011, 02:39
Andreas
Are you able to spot the fault, if you go close enough with your zoom in DM? Typically, you will see a small slit or something like that.
Old   September 7, 2011, 10:31
Graham81 is on a distinguished road
Did you solve your problem? Because from what I can read in your picture (allways read the small print ), the problem is with the settings of the mesher, not necissarily a "dirty CAD". If you didnt solve it, try using an automatic method with advanced sizing function for curvature. Might work .
Graham81 is offline   Reply With Quote
Virtual Topology and "Project to underlying geometry" antonio ANSYS Meshing & Geometry 3 March 9, 2018 04:44
Plz help me "creation IC engine Geometry" khalaf FLUENT 8 September 28, 2016 01:10
What is the meaning of "update the geometry" in cd-adapco press info rubenk STAR-CCM+ 2 March 16, 2010 15:21
