Problem with meshing
Old   April 29, 2011, 09:20
Default Problem with meshing
chetan3189@gmail.com
chetanladha is on a distinguished road
Hi.
I am trying to calculate thermal stresses in a cylinder. i have created the model, selected element type thermal solid "Quad4 node55".
Now when i try to mesh, it shows the following error:
"Element type 1 is PLANE55, which cannot be used with the VMES command. Meshing of volume 1 is aborted."
Can anybody please help...
I am using ANSYS 12.1 Mechanical APDL
Thanks in advance
chetanladha is offline   Reply With Quote
Old   May 2, 2011, 04:23
k_k
Kailash
k_k is on a distinguished road
hi,
as the error says you are trying to mesh a volume with 2D plane element types.
For solid use either SOLID 164(8 node brick element) or SOLID 168 (10 node tetrahedral elements) or SOLID 70 (thermal element)
Cheers
k_k is offline   Reply With Quote
Old   May 2, 2011, 04:33
Thank you very much..
Problem with querying the meshing database in CFX-Pre ashtonJ CFX 18 April 18, 2023 23:49
[Other] Hex meshing problem DM12 patrick ANSYS Meshing & Geometry 7 January 9, 2015 07:21
Gambit meshing problem nana ANSYS Meshing & Geometry 5 August 31, 2009 05:58
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
