mixture mass continuity eqn v.s. volumetric mixture continuity eqn
Old   June 9, 2011, 08:42
Default mixture mass continuity eqn v.s. volumetric mixture continuity eqn
Kai
kaifu is on a distinguished road
Hi all,
I am now developing solver for subcooled nucleate boiling with OpenFOAM. And recently I met a big problem. It comes from the mixture mass continuity eqn v.s. volumetric mixture continuity eqn in pressure equation in PISO loop. It was reported that "the lighter phase is poorly conserved when the mixture mass continuity equation is used" and thus the volumetric mixture continuity eqn is adopted in adiabatic case. However we have to use mixture mass continuity equation if phase change term exists. In my adiabatic case (air-water, 2D upward bubbly flow) I tested both of the eqns and I found it works well with volumetric mixture way. And in case of mixture mass eqn, the velocity of both phase diverged. I can see the max velocity is initially generated in vicinity of inlet. It moves from inlet to outlet, and keeps increasing during simulation. I will appreciate if you could give me any suggestions/references since fluent/starcd have already implemented the subcooled nucleate boiling model. Thank you very much.
// Kai
kaifu is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
mixture mass continuity v.s. volumetric mixture continuity in pressure equation kaifu OpenFOAM 0 June 9, 2011 08:14
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
