FSI interfaces not connected
Old   September 23, 2011, 09:27
Default FSI interfaces not connected
MainzerKaiser is on a distinguished road
As you can see in the attached picture, there is a gap between the two domains that is not supposed to exist. (the displacements are amplified) The interface is somehow opened although data is exchanged and sometimes the solution converges (only in mechanical FSI with adiabatic walls, meaning without heat exchange).
In a fully coupled FSI approach the solution diverges, but I cannot identify the reason yet. It is possible that the gap has nothing to do with that. Nevertheless, I would like to solve that problem first.
The ANSYS.stdout tells me that the mapping was perfectly successful and the warnings refer only to the fact, that there are sometimes not enough stagger iterations.
Since there are no further errors related to the gap at the interfaces, I only post the ending of my ANSYS.mf file.
I hope that you can help me. Thank you in advance!!
edit:
I recognized that the gap gets smaller, if the the solution approaches convergence. There might be no gap at the end. But in my opinion there should be no gap at all any time!
last rows of ANSYS.mf:
_________________________
/prep7
! Tet10/Hex20 Structural
et_tet = 187
et_hex = 186
! Tet10/Hex20 Multi-Field
et_tet_mf = 227
et_hex_mf = 226
alls
! Modify Tet10
*get,etid,etyp,0,num,max
etid = etid + 1
et,etid,et_tet_mf,11
type,etid
esel,s,enam,,et_tet
emodif,all,type,etid
alls
! Modify Hex20
etid = etid + 1
et,etid,et_hex_mf,11
type,etid
esel,s,enam,,et_hex
alls
/solu
! ****** End Command Snippet ******
! ****** Begin Command Snippet ******
! Commands inserted into this file will be executed just prior to the
Ansys SOLVE command.
! These commands may supersede command settings set by Workbench.
! Active UNIT system in Workbench when this object was created:
Metric (m, kg, N, s, mV, mA)
cmsel,s,tempup
d,all,temp,176.85
alls
cmsel,s,tempdown
d,all,temp,26.85
alls
! *********** WB SOLVE COMMAND *********** ! check interactive state *get,ANSINTER_,active,,int *if,ANSINTER_,ne,0,then *endif MFAN,ON
MFTI,0.2
MFDT,0.001,0.001,0.001,OFF
MFLC,SURF,ANSYS,2,DISP,CFX,'WALL_F_R','Total Mesh Displacement',NONC MFLC,SURF,CFX,'WALL_F_R','Total Force',ANSYS,2,FORC,CPP MFLC,SURF,ANSYS,1,DISP,CFX,'WALL_F_S','Total Mesh Displacement',NONC MFLC,SURF,CFX,'WALL_F_S','Total Force',ANSYS,1,FORC,CPP
MFIT,8,2,8
MFCO,ALL,1e-2
MFRE,ALL,0.3,RELX
MFPS,group1,ANSYS
MFPS,group2,CFX
MFSO,group2,group1
CMWRITE,ANSYS,cm
KBC,1
/GST,ON,ON
SOLVE
SAVE
CMWRITE,ANSYS,cm
FINISH
/EXIT
MainzerKaiser is offline   Reply With Quote
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 0 March 10, 2009 22:07
Courant no%23 and sharp corner in 3D jam OpenFOAM Running, Solving & CFD 6 November 18, 2008 08:21
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
