Meshing problem with ansys default mesher
Old   September 30, 2011, 02:30
Default Meshing problem with ansys default mesher
wh88 is on a distinguished road
Hello everyone,
Im modeling the flow over a car and i placed my car inside a rectangular domain. I use the Ansys workbench default mesher. Im able to mesh the car in isolation but when its inside the domain, the status bar freezes at 'generating mesh for solid'. I believe solid refers to the domain here. Because of this Im unable to generate a mesh. Please help me out here.
Thanks!
wh88 is offline   Reply With Quote
Old   September 30, 2011, 11:06
jonathan
jonny_b is on a distinguished road
I think you need to provide more information. Perhaps a screen shot of your domain with and without the rectangle boundary will help, and also a screenshot of your meshed car "in isolation". One thing to ask, when you say "able to mesh the car in isolation" does this mean that you do not have any bounding surfaces outside of the car? If so then I'm assuming you've imported a solid model and not a fluid volume model, if you catch what I'm saying.
jonny_b is offline   Reply With Quote
Old   September 30, 2011, 16:43
Thank you jonny_b for your reply. I have attached some pictures. I modeled a very simple car with an inlet at the front. The first shows the car in design modeler, without enclosure. The second shows the car inside the enclosure. The third one shows the meshed car. Im able to mesh the car only when I do not include an enclosure. I believe you are right in saying I have no bounding surfaces outside the car in this case. The model is solid.
Im using default settings in the ansys mesher. Currently Im not even able to generate a preview for the enclosure.
Any advice would be much appreciated. Thanks!
Old   October 1, 2011, 20:00
jonathan
How did you import the geometry into ANSYS Meshing. Did you import a CAD geometry into Design Modeler? If the car is a solid, you need to essentially take the inverse of the car solid. You can do this in Design Modeler very easily using boolean operations performed on the car solid and an arbitrary "bounding solid" that encloses the car. Once you do this you should have an air solid of the car in an and enclosed volume and the mesher should do what you want.
Old   October 2, 2011, 16:51
the model was cadded in solidworks and imported into DM. This problem only occurs when i shell the car and add inlets and outlets. After importing the model into DM, i created a box and declared it as an enclosure. Then i go to the mesher and generate the default mesh, but it fails.
Old   October 5, 2011, 16:27
jonathan
After you perform the enclosure, does only one part exist? Also, I skimmed over the documentation and it states that you need to ensure that the body you are enclosing is a frozen body. Did you check this? Typically when importing a geometry, the default is to "Add Material" you will want to change this to "Add Frozen". This option is located in the properties view pane when you select the import tree node in the outline view pane.
Sorry I didn't respond sooner, got tied up.
domain, mesh
ANSYS Workbench mesh crashes (ANSYSWBU.exe problem) kondan ANSYS 76 February 22, 2024 02:27
[Other] Hex meshing problem DM12 patrick ANSYS Meshing & Geometry 7 January 9, 2015 07:21
about valve closing problem during ANSYS FSI simulation ivy CFX 4 June 8, 2011 21:01
Line Control in Ansys Meshing Oli ANSYS Meshing & Geometry 4 November 17, 2010 15:35
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
