Home > Forums > Software User Forums > ANSYS
Centrifugal Pump analyses Help
Old   December 22, 2011, 08:18
Default Centrifugal Pump analyses Help
c
c_tas is on a distinguished road
Hello all,
For my design project I need to make cfd analyses for a centrifugal water pump.
I'm using Ansys 13 and Siemens Nx 7.5
I go over an Ansys 12 tutorial and I stuck due to a mismatch between two versions.
Problem 1 is I don't know which wall should I choose as interface side
http://imageshack.us/photo/my-images...question1.jpg/
Second problem is I don't know how to write an expression on post possessing part
http://imageshack.us/photo/my-images...question2.jpg/
I have only limited time and I'm open to all advice that you share..
Thanks in advance
Can
Last edited by wyldckat; September 3, 2015 at 17:27. Reason: disabled embedded images
c_tas is offline   Reply With Quote
Old   December 22, 2011, 13:08
Emre G
emreg is on a distinguished road
do u use MRF or Sliding mesh?
in MRF you dont have to make interface surfaces. choose interior as BC.
emreg is offline   Reply With Quote
release of the ERCOFTAC centrifugal pump - Fourth OpenFOAM Workshop olivier OpenFOAM 8 October 29, 2018 07:49
Autoblade centrifugal pump template mahdi balali Fidelity CFD 3 February 18, 2014 08:56
Centrifugal Pump Cavitation problem or not. ismael.s CFX 13 February 27, 2012 08:00
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
stator-rotor interaction in the centrifugal pump G.H.Lee Main CFD Forum 4 May 25, 1999 07:33
