Home > Forums > Software User Forums > ANSYS
Melting Solids
Old   February 17, 2012, 13:33
Default Melting Solids
Philip
philio63 is on a distinguished road
I have been desperately searching for a way to model the melting of a solid, for instance plastic or polymer.
So the plastic slab, (say 1 foot by 1 foot and 1 inch thick) has a surface subjected to heat, and it correspondingly begins to melt. Also, the slab is suspended off the ground, so the dripping accumulates on the floor, and the viscosity of the melt controls it pool diameter.
Is this possible with ANSYS?? Is this too complicated? I think it can be done with finite particle, how about CFD? Im not looking for superb accuracy in the melt process, more an approximation and most importantly the accumulation of the pool.
Any help is appreciated. been researching for quite a while and turning up nothing.
philio63 is offline   Reply With Quote
Old   February 18, 2012, 04:05
m9819348's Avatar
Ries Bouwman
m9819348 is on a distinguished road
Send a message via Skype™ to m9819348
Hi Philip,
I have been working for quite a while now in CAE (mainly CFD) and your question certainly isn't an easy one!
I believe FLUENT (Ansys) could offer you something, depending on the details you would need.
Maybe open source codes (OpenFOAM?) could help, if you have the time to maybe do some coding yourself?
As you can see in my profile, I work for the ESI Group since 2012. They offer CFD services in the niche areas you are talking about, both consulting and software tools.
I asked some colleagues and we believe that our CFD ACE+ tool might do the trick for you.
Sorry if this looks too marketingy for you, but the simulation you try to run is not that straight forward and as you said so yourself, there aren't many tools out there that can do the trick for you.
Feel free to contact me directly if you would like more information or discuss details.
Dr. Ries Bouwman
Business Development
ESI Group
004369917171525
@riesbouwman
m9819348 is offline   Reply With Quote
Old   March 7, 2012, 18:39
Real Name :)
ComputerGuy is on a distinguished road
Fluent can do this with the melting and solidification module. If I understand you correctly, you want:
  1. A solid suspended in some medium (let's say ice in air)
  2. The solid to melt as the temperature of the air is raised
  3. The liquid from the solid to pool in a container below of the solid
This can be done, but you'd likely need to use UDFs to control solidification and melting of a substance away from a wall. I've done it simulating ice flows on a river, so I suspect you can do this as well. It will take some work to get the UDF code correct.
ComputerGuy
Originally Posted by philio63 View Post
ComputerGuy is offline   Reply With Quote
melting + vof modeeling for PCM in air taw FLUENT 2 August 24, 2018 00:21
Fluent Melting Feature William Kong FLUENT 2 June 19, 2014 12:52
The interactions between two solids in an air region. fshak92 STAR-CCM+ 4 February 2, 2012 06:55
modeling solids feeding to air flow Angeline FLUENT 3 September 15, 2011 12:48
Problem with tin melting... Marek FLUENT 0 May 18, 2005 19:25
