November 27, 2012, 03:31 |
Simluate smoke indoor (Smoke visibility).
Timmy Tang
hi~
I try to do the smoke visbility on Autodesk CFD simulatio, but i can't generate the smoke in CFD i follow the GuideLine, but it is still not success. Can anyone help me here ??? I created a house with two holes. One is on the side, One is on the ceiling. In the middle of the house there is a box where the fire generated. material Volume inside the the house is air. I set it to be variable. The wall of the house is brick. The box in the middle is made by hardwood. Boundary Condition Box: Scale = 1, Heat Generation = 2000W Air: Film Coefficient = 5 W/m2/K, Ref. Temp. = 19 Degree Hole on Ceiling: Volumetic Flow Rate = 50 L/s, Hole on Side : Pressure = 0Pa , Temperature = 20 Degree. Solve: Set Smoke Visibility on Heat Transfer on Specific Extinction Coefficient = 21000 The sign visibility constant characterizes = 3 combustion particulate yield = 0.08 Diffusion Cosfficient = 16 mm^2/s Solution : i set the output quantity is Scalar However, i cannot see the smoke in the CFD. Can Anyone help me I want to create the view like the one in the Guideline. Smoke visibility |
July 2, 2016, 15:59 |
Have a nice time!
Rep Power: 11 |
How can I simulate the fire of diesel for a smoke simulation in fluent?
October 16, 2018, 09:42 |
Nazim
Rep Power: 12 |
HI did you got the method
Thanks |
October 19, 2018, 18:27 |
Have a nice time!
Rep Power: 11 |
Hello, I got a UDF from a video but I did not try it because the project was done by FDS. I can send the snapshot to you
Thanks |
October 21, 2018, 04:06 |
Nazim
Rep Power: 12 |
Please, it will be great
October 21, 2018, 14:47 |
Have a nice time!
Rep Power: 11 |
Here you go Thanks
Car park ventilation and impulse fans | guillaume | Phoenics | 9 | October 27, 2015 05:57 |
Questions about smoke modeling using CFX | rafiktharwat | CFX | 0 | March 14, 2011 11:38 |
smoke (fire simulation) | matt | Siemens | 0 | January 5, 2007 04:48 |
smoke (fire simulation) | matt | Fidelity CFD | 0 | January 5, 2007 04:47 |
smoke & screen | Marko | Main CFD Forum | 12 | May 15, 2000 11:56 |
