Home > Forums > Software User Forums > Autodesk Simulation CFD
Rotating Region and mesh size
Old   May 29, 2013, 09:41
Default Rotating Region and mesh size
Mercier Quentin
QuentinMercier is on a distinguished road
Hello Everyone,
First of all I want to apologize about my english, I am not a native.
I'm Quentin Mercier, a french student in mechanical engeneering.
Today I come to you because I have a problem with rotationnal region with Autodesk CDF simulation.
My purpose is to study a Savonius type wind turbine in dynamics, the huge problem I have is that I can't trust my results, because my mesh totaly influenced my results.
Here is a picture of my work:
http://imageshack.us/photo/my-images...sumaillage.jpg
yellow circle=rotating region
I can give you my boundaries:-pressure imposed at the the outlet
-wind celerity at the inlet (5000mm/s)
-normal celerity = 0 on the other sides of the air volume
I have tried many many many meshes for this problem and here are my results post treated (only rotationnal speed here in RPM during time)
http://imageshack.us/photo/my-images/843/imageforum.jpg
maille=1.00 is my reference mesh (automaticly calculated, approximatively 13,000 elements and maille=0.10 370,000). The 7 first plot has no rotationnal region included and the two last have.
Look at my results ... none of those can be trusted. Maybe you can help me about rotationnal region and with the mesh?
An other question I would ask you is about the inertia you should put in the rotationnal region.
Is this the inertia of the air volume contained in the region?
Or the inertia of my solid?
PS: my rotationnal region have a uniform mesh and I spread it to the entire volume (you can see it 1st picture)
Quentin
QuentinMercier is offline   Reply With Quote
Old   May 29, 2013, 14:12
Apolo
ApoloV is on a distinguished road
This is also being discussed on the Product Forums for CFD
ApoloV is offline   Reply With Quote
mesh, region, rotating
[ICEM] Effect of globle mesh size and mesh independency sujay ANSYS Meshing & Geometry 20 September 29, 2019 07:36
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
