Working on Evaporator. Not getting results as expected |
August 31, 2013, 07:33 |
vijay kadli
Rep Power: 15 |
Hi All,
I am working on a evaporator model. I am tryin to solve it with humidity. Refrigerant passing through tubes are at 1.8'c and air flowing over the tubes is at 27'c I certainly see some heat transfer , but at the end of simulation what I see is temperature throughout the System is 27'c. which is not in the real scenario. only near the inlet of refrigerant into the tubes temp is less than 27'c. but other than that the whole system attains a temperature of 27'c. I dont know what am I missing in the B.C's Please Help |
August 31, 2013, 07:39 |
Autodesk Simulation CFD
Hi every one this is Forex Market in India
online commodity trading I certainly see some heat transfer , but at the end of simulation what I see is temperature throughout the System is 27'c. which is not in the real scenario. only near the inlet of refrigerant into the tubes temp is less than 27'c. but other than that the whole system attains a temperature of 27'c. I dont know what am I missing in the B.C's Please Help |
autodesk cfd, evaporator, heat exchanger, heat transfer modelling |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
Problem: Very long "write" time (~2h-3h) for results and transient results | Shawn_A | CFX | 16 | April 12, 2016 20:49 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
Field Mapper- Mesh refinment | mm.abdollahzadeh | OpenFOAM Programming & Development | 2 | January 24, 2013 09:18 |
Transient Run - Output "Time" in partial results? | evcelica | CFX | 2 | May 16, 2012 21:36 |
