November 27, 2008, 01:10 |
regarding cfdesign tool
I am using cfdesign tool. I am solving fan related problems and solution is not converging after hundreds of iterations even though mesh is good. tool is giving some new errors and warning. Pls clarify.
December 30, 2008, 03:14 |
Re: regarding cfdesign tool
How can you say that Mesh is good. Did you check the diagnostics of the mesh? More importantly did you define the problem correctly and applied the necessary boundary and ambient conditons. Pls check these. If you are facing same problem again, check the under relaxation factors. After doing all these things, if you are facing same problem read the 'Errors and Warning' carefull and try to rectify these. I hope this will solve your problem.
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
CFDesign V10 and Solidworks 2010 | sonodelirii | Autodesk Simulation CFD | 1 | August 25, 2010 20:11 |
CFdesign problems | gaussist | Autodesk Simulation CFD | 3 | July 8, 2009 10:41 |
Can we make a CFdesign Forum | Ram | Main CFD Forum | 1 | February 2, 2009 09:50 |
Problem when launch Cfdesign from ProE | Monford | Autodesk Simulation CFD | 2 | September 22, 2008 20:40 |
