Home > Forums > Software User Forums > AVL FIRE
How to repair Self intersected face problem in avl fame
Like Tree1Likes
  • 1 Post By gncdd
Old   August 21, 2023, 15:51
Default How to repair Self intersected face problem in avl fame
Afshar
mrafshar is on a distinguished road
Hi there
As I mentioned I'm a newbie in AVLfire. I tried to import an assembly from Solidworks to AVL Fire it works for me by parametric CAD section via AVL shape
and after that, I tried to mesh geometry using Polymesh but I just got thousands of self-intersecting faults because of the part contact. I would appreciate any help.
Thnx
mrafshar is offline   Reply With Quote
Old   August 29, 2023, 08:25
gizem
gncdd is on a distinguished road
You can use "Surface Repair" to check and fix geometry errors in the AVL Fame. If you are working on assembly, my advice would be to transfer the parts one by one and check the surface, then combine them with "merge mesh" and make a final check.
mrafshar likes this.
gncdd is offline   Reply With Quote
avl fame, avl fire, self-intersections
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
[GAMBIT] Problem in link face mesh for periodic newbie384 ANSYS Meshing & Geometry 1 June 28, 2013 06:31
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 22:50
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
