Home > Forums > Software User Forums > AVL FIRE
MPI Command not Found
Old   February 10, 2014, 08:40
Default MPI Command not Found
Sameer
sameermdesh is on a distinguished road
I am running AVL fire Jobs on two nodes 20 Cpu's each on PBSpro Linux cluster.
I have situation that every completion of job i see mpi command not found error messages in .e file. Below is fire command line called from python script
cmd += '-name='+'fire '+ ' -project_dir='+os.getcwd() +' ' + '-project='+ inputfile + ' -solver_vers=v2013.1 '+ ' -hostname='+remotehost+ ' -mpi -cpu='+ str(totalcpus) + ' -hostlist='+ machines + ' -case='+casename
If anyone in the community can provide me the solution will be helpful.
Thanks,
Sam
sameermdesh is offline   Reply With Quote
Old   February 14, 2014, 06:54
kschi is on a distinguished road
it is important to check if it is a problem in the envirmeoment (remote connection to each node) or on the example itself. Which error message do you have in the .fla file?
br
kschi is offline   Reply With Quote
Sgimpi pere OpenFOAM 27 September 24, 2011 07:57
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Building OpenFOAM on IRIX lakeat OpenFOAM Installation 7 July 16, 2008 07:27
