Home > Forums > Software User Forums > AVL FIRE
Divergence error
Old   June 12, 2014, 07:36
Default Divergence error
Akash
pakanatiakash is on a distinguished road
hullo
I am new to AVL Fire and I am trying to simulate melting phenomena using the porosity technique available. The case I am taking up is a simple Stefan problem of one dimension. Once I start the iteration I am getting this error, say after 6 iterations -
Problem diverges : Continuity equation, variable: Pressure correction
I tried to change the under relaxation factors and also employed stable schemes but its of no use. The pressure correction is also on.
Could somebody give insight into whats causing this problem. I am using 2011.1 version. Thank you
Akash
pakanatiakash is offline   Reply With Quote
Old   June 13, 2014, 02:29
Changdeo Gaikwad
chang.gaikwad is on a distinguished road
I don't have the experience with the type of problem you are solving. But you might check if you have right pressure initialization. Use the average pressure value that you expect in the CFD domain for initialization. Using zero value of velocity and density sometimes help to give stable start to the problem.
chang.gaikwad is offline   Reply With Quote
Old   June 18, 2014, 06:01
Akash
Thanks for the suggestion. I found the solution but its kind of weird. I ran the simulation in 2013.1 version and it had this problem. I later ran it in 2013.2 version with the same setup and it works just fine. I am assuming there was some bug which was fixed in the later versions. Maybe more specifically in the melting simulation module. But I would like to know if the reason is different from what i thought.
Old   June 18, 2014, 06:06
Changdeo Gaikwad
I have more weird experience with v2010.1. Sometimes when simulation (transient) diverge just restarting it with last saved BC files will converge it.
Its good to know v2013.2 is doing better job that v2013.1. I am planning to start using v2013.2 soon. Thanks for the feedback.
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
