This Blog will describe the process of creating a case that solves the rotation of a square with an incompressible solver. The project is already done and the information will be added to the blog in the near future.
The steps that are going to be explained are:
- Creating icoDyMFoam (incompressible dynamic mesh solver) from pimpleDyMFoam. IcoDyMFoam already exists in older versions of OpenFoam, however, it was created since version 1.7.1 does not include it.
- Solving movingCone tutorial with icoDyMFoam.
- Modifying cavity tutorial by: Adding a square obstacle in the middle.
- Solving the modified cavity case displacing the square.
- Solving the modified cavity case rotating the square.
- Run the application in parallel
If you are interested in some of the topics above, do not hesitate and contact me. As I said, it has already been developed and the information will be posted shortly.
openFoam 1.7.1 IcoDyMFoam CODE
Dynamic Mesh for twoLiquidMixingFoam
I am unable to compile twoLiquidMixingFoam with dynamic mesh.
I am using openFOAM V6. I would appreciate it if I get any assistance.
Please let me know if you want to hear about the details.Posted March 18, 2020 at 14:53 by Bodo1993 -
Tanx Mc
i wanna to add dynamic mesh into viscoelasticFluidFoam solver. my solver didnt include correctPhi.H so i copy it from the existing icoDyMFoam solver. but the error mentioned in the last post, still apeared
would you send me your mail that i send my solver to you.
mail: rasoul_varedi@yahoo.com
tnx
__________
RasoulPosted August 3, 2011 at 03:29 by desert_1250 -
Rasoul,
if I'm not mistaken, you should include a file called correctPhi.H in the folder where you have the solver. Try copying it from the folder of the existing pimpleDyMFoam, pimpleFoam or icoFoam, I think one of them has it.
Good luck,
McPosted August 3, 2011 at 01:14 by McCarra -
Hi McCarra, i hope that you are well
i added the lines mentioned above to the solver, but when i wanna compile it with wmake this error apears:
'correctPhi' was not declared in this scope
how to solve this problem?
tanx
____________
RasoulPosted August 2, 2011 at 04:57 by desert_1250 -
Hi José,
Mmm, I actually thought that the tutorials for pimpleDyMFoam would help making the adaptation between 1.5 and 1.6. I also think it should be as easy as simply stating to use the laminar flow model to achieve the same results, but I could be wrong
Nonetheless, you might want to check out OpenFOAM 1.6-ext, because the -Extend project kept the icoMyDFoam solver when evolving from 1.5-dev to 1.6-ext. You can see the code directly online here: icoMyDFoam git web-browsing
The tutorials for it are also worth seeing, but they very likely will only work with 1.6-ext and not 1.6.x/1.7.x, at least not without some adjustments to fvSolution, if I'm not mistaken.
Best regards,
BrunoPosted February 6, 2011 at 07:54 by wyldckat -
Hello Bruno!
I didn't know that icoDyMFoam was in pimpleDyMFoam since the restructuring of release 1.6. If I wanted to obtain the same results as in icoDyMFoam, what should I do? What I understood is that old icoDyMFoam is included in pimpleDyMFoam but there's no solver equivalent to icoDyMFoam then, am I right?
Thanks for your interest and your help!
Good idea to post it on openfoamwiki.net!
RegardsPosted February 6, 2011 at 07:34 by McCarra -
Greetings McCarra,
Uhm, icoDyMFoam was integrated into pimpleDyMFoam: OpenFOAM 1.6 missing some solvers
But nonetheless, this is a very good tutorial for learning the inner workings of OpenFOAM Very good work!
When you manage to complete it, it would be great if it was also posted at openfoamwiki.net!
Best regards,
BrunoPosted February 5, 2011 at 13:38 by wyldckat -
icoDyMFoam on openFoam 1.7.1
I am looking forward to your blog update :-)Posted January 25, 2011 at 05:33 by jensjo
