Sample .cas files for STAR CCM+
Old   March 10, 2005, 09:12
Default Sample .cas files for STAR CCM+
Amod Kumar
Good day,
I have recently downloaded and installed the STAR CCM+. To practice some simulation, I am looking for .cas files for simple fluid flow phenomena like fully developed pipe flow, Hagen-Poiseulle flow, Couette flow and flow over cylinder.
Can any guide me? I do not have access to Pro-STAR!!
Thanks and regards, Amod
Old   March 10, 2005, 10:31
Default Re: Sample .cas files for STAR CCM+
Jörn Beilke
If you download the "Star-ccm+ -Box set" you get Stardesign together with CCM+. This way you will be able to create whatever you want yourself, even with polyhedral meshes.
Old   March 10, 2005, 16:47
Joe
i get the feeling that if he doesnt have access ot star-cd that means he doesnt have a license and is using the "try out" version with limited functionality. In which case he needs to find himself a mesh
Old   March 10, 2005, 22:45
Amod Kumar
Joe is right. I am using a trial version of STAR-CCM+ available from STAR-CD website. What is "STAR CCM+- -BoxDesign"?
Old   March 11, 2005, 05:07
Joe
Star CCM+ Box is a newly released version of Star-Design which uses Star-CCM+ instead of Star-CD as its "backbone"
Old   March 12, 2005, 03:18
Amod
Dear Joe, Last query! Is the demo version of STAR CCM+ available on STAR-CD website is "STAR CCM+ Box" we are talking about.
Thanks a lot
Amod
Old   March 18, 2005, 12:07
Dr Mesh
The STAR-CCM+ Box Set is a licensed product that combines STAR-CCM+ with STAR-Design. If you are an existing user of STAR-CD you can download it from www.cd-adapco.com:
http://www.cd-adapco.com/news/releases/box_set.htm
The STAR-CCM+ demo version is a free version of STAR-CCM+, that includes sample .sim files that you can use to explore the software. The demo version is fully functional, only limited in the number of cells that you can use (16,000 cells per CPU and a maximum of 2 CPUs). If you have existing Fluent or STAR-CD models that are below this limit you can run them with the demo version.
http://www.cd-adapco.com/products/CCMdemo.htm
Old   March 19, 2005, 04:42
Jörn Beilke
Is the version of Stardesign in the BoxSet now able to import surfaces or surface-meshes from prosurf or is there now a way to get an iges file into Stardesign?
Old   April 13, 2005, 01:07
golabbakhsh
hy dear i need to chip.cas and chip.dat by fluent cd please send to me thanks.
Old   August 2, 2012, 13:13
Default hey
jbr
jonbonraki is on a distinguished road
Originally Posted by Dr Mesh
;168450
hey i there i want to download the demo version of star ccm +but in the link posted above it shows a mapline of the webiste, did they remove the trail version of it..let me know
jonbonraki is offline   Reply With Quote
Writing geometry files in STAR-CD Sachin Siemens 5 April 22, 2008 16:38
Openning files in star-cd 4.02 David Baker Siemens 6 June 20, 2007 01:44
Errors importing Gambit .neu files to Star v3.15 Cb Siemens 1 November 29, 2004 12:39
Star-CD Examples Files David Baker Siemens 3 July 30, 2003 10:54
Script Files for Star-CD? Cary Siemens 3 May 21, 2001 04:36
