savonious wind turbine
Old   May 5, 2015, 12:25
Default savonious wind turbine
davood
davood is on a distinguished road
Dear friends
I have simulated savonius wind turbine in fluent but cp (power coefficient ) is more than 59%(multiple reference frame,unsteady,k-e standard model,...), it is 80%.whats wrong? what should i do to get a correct result?but i think i should set up sliding mesh model?!!what do you think?and i dont know how should i set up sliding mesh model, whats different among mrf and smm setting up?would you help me?
thanks with respectfully
davood is offline   Reply With Quote
Old   May 5, 2015, 15:56
edoan's Avatar
Ethan Doan
edoan is on a distinguished road
does the compuational domain act in a way that "shrouds" the turbine? This could cause a higher cp
edoan is offline   Reply With Quote
Old   May 6, 2015, 08:01
davood
I dont know what you mean?would clear it?
Old   May 6, 2015, 14:18
edoan's Avatar
Ethan Doan
I just mean that 59 % limit exists because the air is expanding as it moves toward and through the turbine if you allow the air no room to expand and you are forcing it all through the turbine because the borders of your domain are too close to the edge of the turbine you may see a higher efficiency. Btw i think for VAWT the theoretical max efficiency should be even lower then 59 %
Old   May 8, 2015, 01:50
davood
thanks a lot dear
Old   May 9, 2015, 01:05
davood
I did that but results didnt change
Old   May 11, 2015, 08:23
edoan's Avatar
Ethan Doan
According to fluent using MRF is "meaningful only for steady flow" perhaps this is something you should look closer into, Im sorry I cant give better advice.
Old   May 11, 2015, 10:42
davood
thanks dear
Old   May 13, 2015, 10:42
Default savonius wind turbine
davood
hi dears
i have simulated savonius wind turbine but i dont know how should i calculate cp?cm which i have got ,are more than 1,is it possible(cm>1)?when i have defined pressure outlet boundary, should i set up reference pressure location?
thanks
savonious wind turbine davood FLUENT 0 May 5, 2015 12:22
Air Flow Analysis around a Wind Turbine NightHawkRaven FLUENT 4 August 12, 2014 17:18
simulating a wind turbine s.q FLUENT 1 October 17, 2013 08:11
Moving reference frame in wind turbine kongl1986 FLUENT 0 March 30, 2013 10:50
FSI - Wind Turbine AUN CFX 13 August 29, 2012 16:44
