Turbomachinery with Star-Cd
Old   January 18, 2000, 02:07
Default Turbomachinery with Star-Cd
Ulf E
I want to try to model a compressor stage. Therefor, I wonder if there is anything published with turbomachinery, using Star-Cd. Thanks in advance Ulf
Old   January 18, 2000, 03:05
Default Re: Turbomachinery with Star-Cd
Joern Beilke
There is some stuff on my home page (www.beilke-cfd.de). Maybe it helps a little.
Old   March 1, 2000, 19:58
Matt Heikkila
Great page! Love the animations. What software tools did you use to create them? Is there a way to export animations from StarCD directly into MPEG or some other video format?
Old   March 2, 2000, 03:39
Joern Beilke
The technical part is very easy. Just use the "scdu" to dumb out the pictures in RGB or GIF fomat ant then use moviemaker/movieconvert. These are the front-ends of dmconvert which is shipped with every SGI. Maybe you have to ensure that there are even numbers of lines and columns before creating the mpeg but I'm not sure.
Old   July 11, 2000, 21:23
Default Re: Francis turbine with cfd
nizam
i'm investigating francis turbine runner with cfd software.Therefore i wonder if anybody can gimme some advices or examples that has been made for that case. thanks alot.
Old   July 13, 2000, 01:07
John C. Chien
(1). Try to type " Francis Turbine Runner" into an Inerenet search site, you should be able to find some information. (2). I came across a paper by Albert Ruprecht, University of Stuttgart, check the web site: http://www.cineca.it/mpp-workshop/fu...cht/index.html
Turbomachinery CFD gumption Main CFD Forum 1 January 27, 2005 23:30
Turbomachinery Simulation with Star-CD andrea Siemens 0 January 9, 2003 07:44
about STAR-CD in Turbomachinery xjz Siemens 4 May 25, 2001 10:44
