[Sponsors] | |||||
We have analized droplet tracks simulated with the lagrange model in Star-CD and we have found preferred direction of the moving droplets, which fly vantaged through cellcenters and avoid crossing cellborders if there is a small angle between droplet motion and cell orientation. What is the reason for this effect? Thank you for your help. Maurice
There is at least a simple workaround for this (long known) problem. Just use a highly irregular mesh (tets).
Maurice,
Do you have droplet collisions turned on? If so, that could be the cause. I assume Star uses a droplet collision algorithm like O'Rourke's in Kiva. In this model, only droplets within the same call can collide. The collisions either result in coalesence or inelastic bouncing. In either case, the result is to turn droplet trajectories away from the sides of cells and towards cell centers. I have a paper under review by the Journal of Computational Physics that documents this problem in Kiva, if you are interested. Regards, David Schmidt |
Mori Nik
Rep Power: 4 ![]() |
Hi David,
I am tryng to implement the other possibilties of collisions in KVIA, I was wondering if you know I should introduce the new satelite drops to KIVA, grateful for any help? |
ninguna
Rep Power: 2 ![]() |
Hi, I'm working with kiva 3V.
I need examples for kiva 3V or kiva 4. non engine application. someone who can help me? someone who has worked with kiva 3v or kiva4? I'm trying to simulate a spray impacting on a surface. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| particle/droplet track data | Jay | CD-adapco | 1 | April 17, 2008 01:28 |
| Why is droplet track file overwritten ? | mic | CD-adapco | 6 | July 12, 2007 10:46 |
| Droplet track coded file | Habib | CD-adapco | 2 | January 11, 2005 21:04 |
| three-phase flow modelling(gas,droplet,particle) | Paksunil | Main CFD Forum | 3 | February 28, 2001 01:12 |
| Why? Preferred droplet track in Two-Phase flows | Maurice Kettner | Main CFD Forum | 2 | February 1, 2000 14:08 |
