July 2, 2000, 03:04 |
referenece data
in Star-cd there are some reference data i am a little confused.
while we input reference date , for example: reference pressure :1e5 cell number of ref. pressure :1 reference temperence :273 reference density:1.205 does it means ? In cell no.1 pressure = 1e5 temperence = 273 density = 1.205 if not, what's the meaning of ref. density and ref. temperature. Will these two number effect the calculation? |
July 3, 2000, 02:01 |
Re: referenece data
With your reference values you set the relative level. When you load your post data you can specify absolute or relative. This relative is related to your reference value. In the inkompressible case where you just calculate dp/dx it is not so important but in the kommpressible case it is important to choose the correct numbers cause you calculate your thermodynamic numbers based on the local values. The boundary conditions you specify are also related to your refference values, so take care what numbers you use and have a closer look to the manual cause there is everytihing written what you have to know about it.
getting data from case and data files | mkrao | FLUENT | 2 | February 10, 2009 00:11 |
Getting Time Series data from saved unsteady data | Atul | FLUENT | 4 | November 26, 2008 05:12 |
how to save case data and data during iteration? | JOHN | FLUENT | 3 | October 10, 2006 19:40 |
Data-processing of magnitude & phase data | diaw | Main CFD Forum | 12 | December 1, 2005 00:39 |
Where can find airfoil data with pressure distribution or aerodynamic data | Ahlo | Main CFD Forum | 5 | January 12, 1999 22:45 |
