GIF Files On Windows NT
Old   October 17, 2000, 10:41
Default GIF Files On Windows NT
MK
When I try and use SCDUMP all I get is a load of rubbish. I have a feeling that the gif files are not in Windows format but are still in the UNIX format where star originated from. Does anyone know of a way around this as I do not have access to UNIX.
Thanks
Old   October 17, 2000, 17:11
Default Re: GIF Files On Windows NT
steve
This is a long-standing known bug of the NT version that we have not found an answer to. However, you can write a neutral plot file (term,,file), go to the "plot" button on the launch bar and select "Convert to Gif" from the list of plot options.
Old   October 19, 2000, 06:52
MD
Just one out of many bugs made especially for NT users. I use (i.g. for movies) SCDUMP PS2. After renaming the files to *.ps (MSDOS ren) I use the batch utilitiy of ConvertPS 4.5 to rotate and convert to gif.
Regards
Old   October 24, 2000, 10:43
david aquilina
hi MK,
i had the same problem. to get around this i just caputered the screen (alt + print screen), then pasted it into photoshop (or any other drawing program) and cropped what i didnt need.
i know this is only a band-aid solution, but it works.
good luck dave
Old   October 25, 2000, 03:58
MK
Hi All,
Thanks for your info, the best way I found was the first method listed, the conversion program did not work at first but after playing with the settings on XVision it produces good results.
Best regards
Old   October 25, 2000, 08:14
steve
MK, Can you tell me what you had to do to Xvision in order to make it work? Steve
Old   October 26, 2000, 03:40
Robert
Why not try the following...
I also use XVision on Windows NT and it works perfectly.
Utility > Save_screen as > Gif...
Then ftp the image to NT remembering to select BINARY ftp instead of asc.
regards
Old   October 26, 2000, 08:27
steve
I don't understand - You mean you save it in gif format directly from Prostar on NT and then ftp it to your NT machine and that fixes it? Steve
Old   October 26, 2000, 09:41
MK
Steve,
Start up your XVision properties, press the colour tab and choose 'let me specify a particular default visual class', choose PseudoColour and turn off Windows system colours, turn on Empty private colourmaps which frees up memory for Prostar. Then change back from PseudoColour to TrueColour and apply. I think you have to restart. The conversion program should then work perfectly.
Regards
Old   October 26, 2000, 11:06
steve
Thanks for the information. You know in our last NT port, we dropped XVision and replaced it with Reflection X. We found that the later versions of XVision were much buggier than the older version.
By the way - just for everyone's information. In preparation for 3.1B on NT, we have been porting the latest version of Prostar and this whole GIF/screen dump problem just went away. It will work in the next release.
Steve
Can we run the es-ice on Windows? Jimmy Siemens 6 March 16, 2009 05:31
Converting ANSYS CFX files to Fluent files Martin S. Rasmussen FLUENT 3 January 30, 2007 15:08
opening fluent data files in windows julie FLUENT 3 December 13, 2005 11:04
windows gl Tom Siemens 2 August 3, 2004 14:06
CFX5 db files migration UNIX-> Windows 2000 Bart Prast CFX 6 September 16, 2002 07:22
